P
It could be any number of things. Try some of these links.
http://www4.ad.siemens.de/-snm-0135030360-1095414968-0000030251-0000005507-1
097234336-enm-WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=csius&objid=19
439600
097234444-enm-WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=csius&objid=17
830226
097234562-enm-WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=csius&objid=91
26124
IF you also get the message "Database Server not available, then try this.
You should check that your file shares / enable commands are correct on the
server.. With a client/server configuration the following would be enabled:
Enable WinCC project folder
Enable 'aplib' folder on the path: ...\siemens\WinCC with the name ScriptFct
and in addition, with the redundancy option, enable folder 'RedTemp' on the
path ...\siemens\WinCC
Note:
Enable commands are normally automatically set by WinCC, but it can happen
that they are reset by the operating system.
If none of this works then go to the Service & Support Website and submit a
request for help.
http://www4.ad.siemens.de/WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=cs
eus&aktprim=1&startNode=16604318&nodeID1=16605654&basisview=4000002&wttree=s
ervicesnodes&foldersopen1=-17-26-&jumpto=26
Ron Powers
439600
830226
26124
Note:
request for help.
Ron Powers
