Hello folks,
Stumbled upon this post while searching the internet for a similar issue that I was facing, and thanks to @PhilCorso 's suggestion, I've attempted to elaborate on the problem, provide various scenarios and its behaviors, and conclusion (including a very recent one I've come to) including the next steps I plan to take. Though I "think" I've found a way to eliminate the most dangerous problem of getting shocked (disconnected earth), I still have a few questions-
Apologies in advance for the long post- but I believe the details will help you to help me better. Hopefully "Safety" is the right category for this post.
- Is it normal for the UPS to output half of the phase-neutral voltage to the phase-earth and neutral-earth when running on the battery? Or is it something I should be concerned about? The voltage measured in scenarios 2, 3, and 6 is what I'm talking about. The UPS in question is APC BR1000G-IN (India specific) (also known as Back-UPS Pro 1000 I guess)
- What would typically happen when appliances not requiring earth are connected between phase and earth instead of phase and neutral? Though I plan to check the same with the appliances connected in the problematic section, does anybody know for sure that this could be the reason why the post-earthed (to the faulty room) voltage on the earth pin raised from 1-3V to 6V?
- How I plan to check that is by testing the continuity between neutral at a socket and the non-phase lead connected to an appliance (when the phase to the appliance is turned OFF). Do I have to disconnect the power to avoid frying my multimeter?
- This may sound stupid, but I may have done this for a ceiling fan unknowingly while installing it due to a lot of wires that were there at the fan's hang point and I connected the supply based on a previously taped wire where the potential difference of 230V was present and now I remember that there were more than just 2 wires that were taped.
- Is the assumption that the Phase-Earth voltage would be the sum of the Phase-Neutral voltage and the Neutral-Earth voltage correct? Could it be that it is not measured by a regular multimeter? Earlier I had crazy low values (Phase-earth showed like 18v or something when my UPS technician showed it to be over 180V using the probes of his (more expensive) clamp meter) being shown by my multimeter, but today, the values seem reasonable (absolutely have no idea why).
