I'm curious about the reason for the difference in lube oil tank differential pressure during gas turbine startup and shutdown. During startup, the lube oil tank differential pressure is around 8 inches, but it decreases to 6 inches when stopped. I don't quite understand why there is a difference. During both startup and shutdown, the lube oil pump is continuously running, and the LUBE MIST SEPARATOR fan (88QV) is also continuously running. For reference, the role of the LUBE MIST SEPARATOR fan is to create a negative pressure (-) in the tank to extract insoluble gases and facilitate the discharge of lubricating oil from each bearing to the Oil Tank. In my opinion, it might be related to the decrease in tank oil level as lifting oil is supplied when the RPM drops below 50%, and the decrease in oil temperature when stopped, but I'm not sure. The differential pressure I'm referring to is the difference between the internal pressure of the tank and the external pressure (atmospheric pressure).
