Have you tried talking to Omron direct, this PLC is out of production by some time, conversion of the software ok apart from a drum sequencer that used to be used, however in most case a standard shift register works ok. You dont say if you are state side or not. But Omron Tech support in the UK is pretty good, give them a bell, they should be able to make you a copy.
