Do we need a separate connection system for Predictive maintenance Machine learning?
Hi Gurus,
We have control system connected to CMMS system for condition monitoring database.
If we need to implement Predictive maintenance, can we just use the same data base? Or install new connection?
Please kindly share with me your experience on Predictive maintenance implementation.
Many Thanks,
Lydia
To implement predictive maintenance, you can leverage the existing connection between the control system and CMMS for condition monitoring database. Utilizing the same database allows for seamless integration of predictive maintenance algorithms and analysis, optimizing efficiency and minimizing costs. However, depending on the complexity of predictive maintenance requirements, you may need to enhance the database or establish additional connections to accommodate new data sources or analysis tools.
