F
Hi guys,
We are using GE MS9001E Gas turbine. We have problem on low output after smoke coming out from the extraction pipe from bearing #2.After running for 1 hour in base load, the output has started to decrease, from 110MW to 99MW.
There are some data recording during the event:
CTIF, inlet temperature: 31DgC
CPD, compressor discharge pressure has dropped from 10.2 to 9.5 bar
Bearing #1/#2/#3 has higher lube oil temperatures, increase about 10 dgC from normal value.
Highest is at bearing #2, for 97.72dgC. Compressor discharge temp; 382dgC.
Bearing metal temperature for bearing #2 increased up to 92DGC. Normally temperature is around 87DgC.
The air for cooling and sealing is taken from the extraction of Stage 5 from the compressor. I am quite confused whether the cooling/sealing air had low pressure or the bearing #2 itself. Need assistance on how the output has affected, and root cause of the problem, either the cooling air low pressure or the Bearing #2 has damaged.
Thank you. Cheers.
Thank you. Cheers.
