R
We are operating a GE Frame 5 machine on 100% Gas fuel at around 65 degree C. Will it be more economical/energy efficient to raise the temperature of Gas to a higher temperature say 80 deg C? We have ample scope for the same in our gas heater. Will the Gas turbine fuel nozzles be affected at higher temperature of gas fuel? Can you cite example where higher temperature of gas fuel is currently is use?
For information - we are using RLNG as gas fuel. Current flow is around 150 T/D for 22.5 MW machine.
