HI.
We have in our site two turbines MS6000 both running on gas fuel (not DNL), control system MKV TMR <I>. We have noted that with a target of 19 MW (demanding of the grid) both turbines run with 19 MW each of them. CPD:9,21 bar (both), fsr:36,73% / 36,41%, TTXM:375 / 373 ºc, igv:85,8 (both), tnr: 101,96% (Both), respectively.
Now when the target of the grid is for example "Base Load," we note a significant difference in load of both as following:
CPD:9.51 / 9.67 bar, fsr:59.65% / 60.09%, igv:85,3 (both), tnr: 103,82% / 104,03%, respectively. dwatt: 31.9 MW / 33.5MW.
We suspect that difference of load of both turbines is due to the difference in cpd. But why we don't have that difference in cpd when both turbines run in a load below 20 MW. The stroke of the GCV and SRV and IGV are within the values of control spec.
Is it a problem with the compressor discharge?, Do we need a wash compressor?, since we have checked the cpd transmissor and 20 CB and both are ok.
Thank you very much.
