Hi there..
I have issue on our BN. Recently One of displ. probes (L232-HIGH SPEED SHAFT) on the load gear box was activated and reach max level causing our gas turbine to trip. When checking on the BN monitor, the 1st alarm come out (yellow) then we raised up the loading hopefully to lower the vibrations (from15MW to 25MW). but the thing getting worst when BN show that the vibration reached at max (red). is it possible the alarm signal sent to the relay that may cause our gas turbine to trip? Upon checking on our gas turbine Marx V it only stated trip on bently nevada rack and displ. probes BN high speed alarm. After the GT was trip, we tried to start it back but not reaching FSNL, the L232 activated again reach max (red).
