T
I have a BLDC motor that behaves as expected as long as I am not keeping the speed constant with PI speed control with PWM.
The torque is positive, the phase current alternates as expected.
When I try to control the speed (which was ramping up to a target speed), the motor brakes to stay at the target speed.
As expected, the torque becomes negative. However, to keep the speed at the target RPM, the curve for the torque (and the input current to the inverter stage) becomes alternating (more specifically sinusoidal between positive and negative values).
This infers that to maintain the speed the motor requires alternating (negative and positive sinusoidal current). Is this an expected result?
