Hi Guys,
I've got a brand new Cx8091 (PLC from BECKHOFF with integrated BACnet/IP server). I've tried many times to read values in the PLC from Kepware via BACnet/IP. But it didn't work. I read kepware and Beckhoff documents but I couldn't figure out the problem. By the way, I can read values with BACnet client which is defined in TwinCAT.
Does anyone use KEPServer as a BACnet client on a BACnet network??
