K
I have a six inch Rosemount Magnetic flow meter in service on a caustic scrubber. The meter measures the pump around from the sump back to the top of the scrubber. In normal operation it reads 200GPM. When the unit is started there are no problems, as it runs over time the meter starts to swing and lose the upper-end say between 20-150 GPM. After a few days the top end drops off further and a few days after that it just stops reading flow altogether. The meter is fine, no alarms no problems reported...it just can't see anything. Ther is still flow through the pipe, no plugging. We recently bought a conductivity meter for the lab and I tested samples for as far back as I could go and got the following.
Meter swinging @ 215 millisemens on 8/12
Meter barly regeistering flow @ 225 milliseamens 8/20
Meter flatlined @ 285 milliseamens on 8/22
It seems that the higher the conductivity the more it effects the meter.
When we take the unit down and clean, the meter comes back and works fine for awhile (6-8 weeks) then starts to swing/drop-off until no flow signal
At this time I have no conductivity numbers for a "clean" system.
I have stated that this seems to be more of a process/application issue than a meter issue but for some reason I still get to try to make it work.
There is an unknown amount of Hydrocarbon in the sample. I say unknown because the samples don't seem to have the seaperation I was expecting to see so I could judge an amount.
I know Hydrocarbons are bad for Mag meters but what about very high conductivity?
